Buying Struts.
For those of you with FE4 suspension where did you find rear struts at for out cars? I can find struts for the front. I have tried KYB online but no luck. The struts for FE3 suspension will not work as a 17 inch rim and tire will rub the part of the strut where the spring sits in. FE4 suspension came on Supercharged Montes only.
good thread ya i feel my 07 lt with 17s rides like crap{i told the dealer while i had my warranty and they replaced the stabilizer links, lol} and am in the market for new struts but am scared cause everything i see says only fits 16s or less. has anyone upgraded there stuts that has part numbers???
I put a set of KYB AGX's on my 04 w. FE4 suspension, they fit with the stock 17"wheels no problem. the catalog listing says except with Special handling package (FE4) but thats only because the FE4 spring and damping rates are different (stiffer), physical size is the same. Part #'s are 734058 for the front 734059 rear
