Winter Project: Rust Removal :D
Not quite Winter but I decided to get a head start on my winter project
My Monte's started to get pretty rusty on the underside so I plan on eliminating as much of it as I can over the winter. Only going to be doing a little each day/week so I thought I'd start a thread for pics and updates. Also, I plan on doing quite a bit of suspension work. Hopefully going with AGX struts and SSC Springs. May go with GR2 struts just because of the price.
Pulled a lot of stuff off tonight. Going to start up front and get the radiator support cleaned up. Removing my intake and battery and killing the rust that's started under there as well.
I'm thinking this is what I'm going to be going with for the underside. Eastwood seems to have some pretty good products for restoration and fixing rust. Not sure how I feel about just applying this stuff directly over the rust? May sand it down a little first.
Wish this stuff wasn't sooo expensive Stilll unsure of which to go with.. I'm planning on doing it all the right way so I'm not doing this ever again
Hopefully tomorrow night I can get a start on sanding down the rust now that everything is removed.
Here's an updated pic of the engine bay.. Clearcoated my mounts and braces so there's no way it's rusting this time Considering getting them powdercoated or chrome plated, that kind of stuff will have to wait though, I need the money for rust removal right now lol.
Baking the clear coat
Freshly painted Painted the HVTB too
I've used POR15 for a lot of projects. Properly prepped, that stuff does the job!!! When you use it, must be on porse metal OR use the Metal Prep etching spray! And yes, it is hard stuff (I remember trying to feather sand some that was brushed on, I think the surrounding steel was going to sand off before the POR15).
I thought about a rhinoline type of coating but there's so much rust I'm thinking Por15 will be my best bet.
Thanks! Going to be a slow moving project but totally worth it.
