Sun Roof Problems
Old May 30, 2012 | 02:10 AM
03redSS's Avatar
Default Sun Roof Problems
Hi I have recently had a problem with my sunroof. I don't know what happened. I shut it one day and it started rattling making alot of noise. It closed but it seemed like it was shaking as it did so. This past week has been in the 90's and even reached 100 So I like to open the sun roof. It still opens making no noise when it opens and it stops half way when it opens. When it shuts it makes all kinds of noise but it shuts. I don't know what the problem is if its off the track some how or anything. I don't know were to look to see if something is jammed. I had it someone open and close it while I looked at the top and I didn't see anything out of the normal. Help?
Old May 30, 2012 | 02:48 AM
MillerMonteSS's Avatar
2010 Monte Of The Year
This same thing happened to my '06 SS. I figured that the grease was worn out after so many cycles of open/close. I applied some gun grease to the runners that I happened to have and it solved the problem. My guess is it just needs a little lube.
Old May 30, 2012 | 06:14 AM
Explore the below links...I hope it helps you...Good Luck
  1. Power Sunroof Woes - Monte Carlo Forum - Monte Carlo Enthusiast Forums
  1. <CITE>montecarloforum.com/forum/general.../power-sunroof-woes-8818/</CITE>
  2. 10 posts - 5 authors - Apr 5, 2008
  3. Okay, so I know that the tilt and slide power sunroofs on our car suck. ... and when it leacks im thinking it will leak in the front on the sides. ... Chevrolet Lumina - Monte Carlo[/align][align=center]Sunroof Information Page[/align] ...
  4. sunroof problem‎ - 1 post - Nov 19, 2011
    Sunroof help‎ - 10 posts - Sep 22, 2011
    Sunroof issues‎ - 9 posts - Mar 21, 2011
    Sunroof Problem‎ - 10 posts - Jun 16, 2008
  5. More results from montecarloforum.com »
  6. Get more discussion results
  7. sunroof - Monte Carlo Forum - Monte Carlo Enthusiast Forums ...
    <CITE>montecarloforum.com/forum/tags/sunroof/</CITE>
    2000, carlo, chevy, fix, fuse, monte, mot, open, sunroof problem · MONTE CARLOS -SS- 2000 FULL. 11-19-2011 11:05 PM by MONTE CARLOS -SS- 2000 FULL ...
  8. Chevrolet Monte Carlo Sunroof Problems - Car Forums - Edmunds
    <CITE>townhall-talk.edmunds.com › ... › Chevrolet Monte Carlo</CITE>Cached
    2 posts - 2 authors - Aug 29, 2010
    Chevrolet Monte Carlo Sunroof Problems discussion in the car forums by Edmunds.com.
<LI class=g><TABLE style="WIDTH: 100%" class=ts><TBODY><TR><TD colSpan=2>
</TD></TR></TBODY></TABLE>
Old May 30, 2012 | 10:22 AM
03redSS's Avatar
I am gonna try to use the white lubricant grease that I saw some people talking about. I dont think its the motor because it runs fine just I think it might be sticky or dirty on the rails and that thats what is causing it to click and open and close slower than normally. Hopefully it is just that because that is a much cheaper fix then having to replace the motor. Would I be able to pick this grease up and just any regular automotive store? What would you recommend to use to degrease what is already up there? Thanks for everything.
Old May 30, 2012 | 10:37 AM
Check out the below links & vid's & it will show you how to do it...You should be able to find the lubricant grease at any hardware or auto stores...Good Luck & let us know how you did (?)
  1. [*]
  1. More videos for how to maintain a sun roof ? »
rj
Nov 11, 2007 10:10 PM
J_Bru_Ha_SS
May 15, 2007 04:20 PM
rchurch
Mar 29, 2007 04:31 AM
GrandPaDave
Dec 29, 2006 05:12 PM
chrisv
Aug 20, 2006 03:24 AM
