Sunroof help
Old Sep 22, 2011 | 07:53 AM
Default Sunroof help
morning everyone, when i bought my car the po had told me the sunroof suposidly didn't work but she never tried it. This morning curiosity got the better of me and i gave it a try and it doesn't work
Now i have a bigger problem, i cant get it to close all the way, the back part of it will not close all the way. I tired pushing it i tried opening and closing it and pushing it, nothing works. I'm currently at school, so if anyone has any advice it would great so i dont end up with a wet interior
Old Sep 22, 2011 | 08:28 AM
Hi `Keane,
Below are some links on your problem..
The one from the MCF is from our old site, but still concerns your problem...I hope one of our expert member's can also post infor to help you ~> Good Luck 4-Sure
Power Sunroof Woes - Monte Carlo Forum - Monte Carlo Enthusiast Forums
montecarloforum.com/forum/general.../power-sunroof-
10 posts - 4 authors - Last post: Apr 10, 2008
Good Luck `Space1995-1999 Chevrolet Lumina - Monte Carlo[/align][align=center]Sunroof ...
Flip up sunroof install...
GM Recall on 3800 3.8-liter V6 Cars - Monte Carlo Forum - Monte ...
More results from montecarloforum.com »
Get more discussion results
1997 Chevrolet Monte Carlo Problem Chevy Sunroof Won't Close
www.2carpros.com › ChevroletMonte Carlo - Cached
Interior problem 1997 Chevy Monte Carlo 6 cyl Front Wheel Drive Automatic 101000 miles I just got this car after it's been sitting for two years...
Why wont my 2000 Chevy Monte Carlo Sunroof won't close
wiki.answers.com › ... › American CarsChevroletChevy Monte Carlo - Cached
You +1'd this publicly. Undo
What do you do when the door wont close on a 1997 Chevy Monte Carlo? I have the same problem, but i have a '95 ... Why won't sunroof close on infiniti g20? ...
How do you fix a sunroof that won't close on a 2001 chevy monto carlo
What do you do when the door wont close on a 1997 chevy monte carlo? ...
Old Sep 22, 2011 | 08:55 AM
thanks for the links space, they'll help in the long run, anyone have a quick fix so i can maybe get the darn thing closed?
Old Sep 22, 2011 | 09:08 AM
Hi `Keane,
Found the below on a search....I hope one of our member's that had your problem sees your thread & can post some infor to help...Good Luck.. Below is from a 98 Monte..
Manual Solution for 1998 Monte Carlo z34:
Pull down interior design near button, it's all velcro underneath. The motor is silver and on the bottom of it, there is a white colored ****, that has a slot for a screwdriver. I believe to close it is counterclockwise. For this you will need VERY small screwdriver, and requires much force with a small one.
I poked a hole through the interior, and used a longer screwdriver. More torque and less pain on hands. Poking a hole sounds weird, but to be honest, it won't be noticed much.
The sunroof on my 98 - FixYa
Source of above infor...Good Luck 4-Sure..
Wish you good weather & no rain
Old Sep 22, 2011 | 09:19 AM
i like the screwdriver one, i have some tools in my trunk and will certainly be trying that before i leave, thanks space
Old Sep 22, 2011 | 09:37 AM
Your Welcome `Keane,
I hope that works, but I also hope one of our member's that may have had this problem chimes in b-4 you attempt to poke a hole in your headliner..
I've never had a sunroof, , but I hope your track isn't messed up & jammed Good Luck 4-Sure...Pray for sunshine 2 : )
Old Sep 22, 2011 | 09:54 AM
Sometime's I have to push the button repeatedly to get it to close all the way. Or you could try this
Old Sep 22, 2011 | 10:04 AM
03SSLE's Avatar
LMAO...at least they could have color quartinated the bumbershoot to the car.
Best of luck, Keane. I hope you get it closed before it rains.
Old Sep 22, 2011 | 12:28 PM
well after much prying opening and closing only half of it went down completly. I had to seal up with this crap and it looks like freakin crap The arm on the left side refuses to go down letting the window drop
File Type: jpg
Old Sep 24, 2011 | 03:31 PM
JaxJim's Avatar
My sunroof has similar issue. The plastic bits and pieces in the tracks were jamming up. I had to remove the glass so that I could push the tracks back into place. I had to get the mechanism closed WITHOUT the glass in place, then I re-installed the glass. The glass come out after you unscrew a couple (four or six-I forget) torx head screws. Pretty easy job. Give that a try.
