Black headlights
Old Mar 18, 2012 | 06:24 PM
sisson16's Avatar
Old Mar 18, 2012 | 06:29 PM
Franks 03SS's Avatar
2011 Monte Of The Year
those should work great man!
Old Mar 18, 2012 | 06:31 PM
sisson16's Avatar
Wont they bE a pain to get both wheels the same
Old Mar 18, 2012 | 06:55 PM
03SSLE's Avatar
A friend of mine used that exact style of adjusters, and without some additional hardware you will be under the car every other weekend adjusting them...or at least he was until I looked at them for him. The problem is the nut that holds the upper plate and/or the nut that adjusts the lower plate will turn on the threads of the screw and you will lose height. To remedy the problem you need to get 4 more nuts and 8 lock washers. Slide the screws through the upper plate as normal, but before you thread a nut on put a lock washer on the screw. Then thread the nut on. Install the lower nut and plate as normal and make your adjustment. Once you have done that install a lock washer and nut under the lower plate and tighten. This will prevent the nuts from coming loose due to vibration.
Old Mar 18, 2012 | 06:57 PM
I needa look into this stuff my car drops with my subs in
RaeRaeAlmighty
Jun 14, 2014 08:11 AM
RickAKATed10
Aug 10, 2011 10:26 AM
irulesoha
Apr 2, 2010 01:04 PM
2000_BLACK_SS
Jun 9, 2007 09:52 PM
kyle08
Aug 29, 2006 10:43 PM
