Black headlights
Old Mar 18, 2012 | 03:57 PM
Franks 03SS's Avatar
2011 Monte Of The Year
Originally Posted by sisson16
So basically get the twist in ones if they have em? Im on my way ill just have to check them out when i get there
yea they seem the easiest to me, they should be able to tell you which ones you need and how much it'll raise the car
Old Mar 18, 2012 | 04:30 PM
sisson16's Avatar
Ok i got some adjustable ones. Ill get them on next weekend since ill be outta town working this week. Hopefully theyll work good
Old Mar 18, 2012 | 04:42 PM
sisson16's Avatar
Should i take them back and get the twist in ones? The only twist in ones they had said up to 1 and a half inches. The back sits about an inch and an eigthlower than the front.
Old Mar 18, 2012 | 05:42 PM
what's wrong with the adjustable ones you just got?
Old Mar 18, 2012 | 05:47 PM
sisson16's Avatar
Nothings wrong with em i just think itll be easier putting the twist in ones in instead of having to adjust to fit the same
Old Mar 18, 2012 | 06:00 PM
hmm, are they rubber? if so you shouldn't really have an issue
Old Mar 18, 2012 | 06:11 PM
sisson16's Avatar
No the ones ive already bought are metal with bolts and you have to adjust them to fit. They have 2 plates with a half moon cut in them which fits around the shock and u tighten the bolts to spread the shock apart to raise it. The twist in ones they had were also metal but u just twist them in with a ratchet theres no adjusting to make both sides the same there just automatically the same
Old Mar 18, 2012 | 06:12 PM
my rubber ones were fairly easy to put on, if you get the twist ons im sure it wont raise it the full inch and a half. are you afraid it'll raise it too much? :p
hmm, i would think those would work fine and even a little better maybe than the metal twist in ones, you would think the twist in ones would pull paint off
have any pics of em?
