Black headlights
Old Mar 18, 2012 | 02:41 PM
sisson16's Avatar
Default Black headlights
Ive been looking online for a while at them but im not real sure where the best place to get them from is and also if there are really any diffrences in the diffrent brands or if basically just anything was diffrent. Some are cheaper and some are more expensive so i dont want to just jump into something without knowing. Any help id appreciate it.
I have a white 03 SS with black 20s, black IPCW tails, dark tint and black pinstripe so i want some headlights that are noticably black. Ive never seen any in person so i dont really know how theyd look. If anyone with a white monte with black headlights has any pics please post one up for me.
Another question is that i have a lot of weight in the trunk (subs, box, car audio battery) so the rear sits lower than the front by about 1.5 to 2 inches. Is there anything anyone recommends to level the car out in the front. I dont want to put taller or stiffer in the rear but maybe lower the front a little. I dont really know which would be the best way though.
Old Mar 18, 2012 | 02:51 PM
just get what's cheapest, they're all from the same manufacturer, just different sellers...
Depo Pair Euro Style Black Halogen Headlights Head Lamps 00-05 Chevy Monte Carlo | eBay
here's some black housed headlights on a white monte, it's on frank's monte
Also for the springs, your car may ride weird if you just lower the front, most people put in stiffer springs or spring blockers for the rears to level them out
Old Mar 18, 2012 | 02:56 PM
sisson16's Avatar
Alrite thanks. Would the stiffer springs in the back make it ride weird to?
Old Mar 18, 2012 | 02:59 PM
i haven't read anything with people having problems with them yet
https://www.wbodystore.com/Rear-Heig...ngs-p-304.html
Old Mar 18, 2012 | 03:19 PM
sisson16's Avatar
Are those the ones you suggest i get? Or should i do some measuring and see exactly how much the diffrence is? Do i need any special tools?
Old Mar 18, 2012 | 03:22 PM
Franks 03SS's Avatar
2011 Monte Of The Year
hey man i also read your pm, i didnt buy my headlights new. i traded them for my stockers so i couldnt tell you what brand they are
for your springs you could also try spring boosters first, they'll run you just under $10 or so at your auto parts store they raise your car a lil with all that weight
i installed rubber ones on mine and it raised it a good 3/4 inch :p
the spring boosters look like this
i've seen 3 diff kind....
these twist in between your coils with a ratchet
these rubber ones go in between your coils too
and these also go in between the coils haha, they're made of rubber as well
Old Mar 18, 2012 | 03:24 PM
here's a better pic of my black headlights
Old Mar 18, 2012 | 03:40 PM
sisson16's Avatar
so with the spring boosters you just take the wheel off and put them in the middle of the spring and when it loads it just stops it from going down as far and overall makes it sit a little higher all the time?
Old Mar 18, 2012 | 03:45 PM
sounds about right...
have to jack your car up some though, guy at auto parts store told me i had to get my spring removed to install the rubber ones but with a little lubricant they slide in easier
the twist in ones are much easier to install he said, all you do is position it in between the coils and use a ratchet to twist it in into place
Old Mar 18, 2012 | 03:52 PM
sisson16's Avatar
So basically get the twist in ones if they have em? Im on my way ill just have to check them out when i get there
