Riveting on glass
Old Jun 25, 2018 | 09:15 PM
Dj_bosse's Avatar
Default Riveting on glass
Does anyone have experience with replacing the rivets on a window regulator? I'm worried about shattering the window since I need to rivet the regulator to the glass (not my Monte). I'm hoping I'm just being paranoid about it but really don't want to break it.
Old Jun 26, 2018 | 10:03 PM
I'm curious what you are working on?
The only thing I recall seeing on some cars that is riveted in are called "sash clips". Luckily, I never had to replace ones that were riveted. I would think you would have to drill out the rivets, the new clip would then need to be bolted in??? If so, I would assume a lock washer in the equation.
I replaced a sash clip on my Grand Am because it cracked. Those were glued on. With the right prep, gluing the new one on was successful on the first try.
Old Jun 27, 2018 | 06:56 AM
Dj_bosse's Avatar
It’s a 97 Town Car. There are what appear to be nylon spacers on the window itself, looks to be clipped on so the pressure from the rivet isn’t directly on the glass. When I drilled out the old rivets the spacers didn’t break and they didn’t give me new spacers. I ended up using Loctite nuts on them but I don’t want them too tight and break the window, so the window doesn’t seal perfectly at the top when it’s up
Jester_20
Aug 24, 2014 02:29 PM
RockAuto
Vendor for sale section
Feb 25, 2013 12:11 PM
RickAKATed10
Sep 29, 2011 05:33 PM
kennyjohn
Oct 9, 2010 03:29 PM
big green dog
Jul 28, 2005 05:16 PM
