Camaro Frame
Old Dec 19, 2011 | 10:09 PM
DRuben's Avatar
Default Camaro Frame
Anyone know the dimensions of the third generation (1982-1992) and fourth generation (1993-2002) camaro frames?
Old Dec 20, 2011 | 06:10 AM
They are not full frame cars. They are unibody. So it might be rough to get those dimensions.....
In all the data I have on my 3rd gen, I don't think I have anything that shows frame measurements.
Can I ask what you're up to??
Old Dec 20, 2011 | 10:08 AM
Yes i would like to know what your up to as well, but they are unibody so no real frame on them
Old Dec 20, 2011 | 10:49 AM
Jester_20's Avatar
YEA! what cha doin?
Old Dec 20, 2011 | 10:58 AM
Thinking about a RWD swap?
Old Dec 20, 2011 | 11:00 AM
Jester_20's Avatar
that's my guess
Old Dec 20, 2011 | 03:35 PM
04chevyboy's Avatar
One member did it with a white monte i think it was,for got the motor also,maybe 350?
Old Dec 20, 2011 | 03:43 PM
Enzo354's Avatar
STILL SLOW
I always thought the third gens were body on frame? I guess I never closely looked at them. As for the monte that is rwd, he did an ls1 swap into it.
Old Dec 20, 2011 | 06:17 PM
Nope.... They have a unibody structure. They do have an engine cradle (I believe referred to as a K-Member). Then it has some frame pieces that weld to the body on the front and back.
Below is an OLD pic from when we changed the floor pans on my Camaro. This was after we got the old passenger side floor pan liberated from the body. That curvy piece with the read arrow is all you have to a front frame. There is a matching one on the driverside. there were two members like that on the back. They are actually welded to the floor pan. This is why in the 3rd and 4th gen F-bodies, rotted rocker panels are a HUGE structure problem. And if you doors don't hold right only make things worse on the body.
As part of my Camaro restoration plans, I have UMI Performance subframe connectors I will be adding (making the car dang close to a full frame car).
Old Dec 20, 2011 | 06:25 PM
Enzo354's Avatar
STILL SLOW
Wow, no wonder they flex so bad!
