trans or fuel pump problem
Old Mar 25, 2011 | 03:43 AM
joeg1286's Avatar
Default trans or fuel pump problem
Hey what's up guys I'm new to the site and wanted to see if someone can help me figure out if my trans is goin out . I'm driving asnd suddenly the gas peddle just starts like choke and the trans sometimes will not switch unless I ease the gas. Now my gas gauge has been out for a while also.
Old Mar 25, 2011 | 06:28 AM
obnoxus's Avatar
Do a " brake torque " and have someone listen at the back of the car for jetting sounds to rule out a catalytic convertor going bad
Old Mar 26, 2011 | 09:02 AM
Caffenated1's Avatar
I've had the same issue with the tranny, it seems to be a "Chevy thing" as far as that's concerned. (the switching gears thing) My 02 cavalier as well as my mom's trailblazer do the same thing and neither have had any issues with the tranny other than that occasional quirk. As far as the choking issue, i've learned it can be several things.. 1.)as stated above, your cat could be clogged. 2.) you could have a fuel filter that has gone bad. 3.) fuel line leak somewhere. 4.)bad gasoline (it DOES happen) 5.) fuel pump going bad. Check all the easily check-able things before spending a ton of money replacing everything.
StrongTakeover
17
Nov 30, 2019 10:50 PM
ReaperSS
Aug 29, 2014 11:35 AM
The_Maniac
FWD Tech Guides '95-'07
Jan 26, 2014 05:54 PM
Mdecourcey
Jun 27, 2013 08:20 PM
03SSLE
Dec 29, 2012 09:41 AM
