Fuel Pump Power Problem
Old Dec 29, 2012 | 09:41 AM
03SSLE's Avatar
Default Fuel Pump Power Problem
(A reply from another thread - Moved for exposure)
Originally Posted by Deron Williams
hello forum im having a problem with trying to find out why the fuel pump isn't getting any power i dropped the tank to see if the fuel pump was good because before i dropped it i listened through the gas cap first and it was running the first time the battery was going dead so i charged it and tryed it again with in 30min then no sound at all , relay is good fuse good and still no power what else could it be please needing your help? sorry it is a 1997 monte carlo z34 3.4l
It is normal for the fuel pump to only run a couple of seconds then shut off when you turn the key on. This primes the fuel system and builds pressure in the fuel line. Once the vehicle starts the fuel pump will be provided a constant supply of power. What is the problem you are having? No start? Start and die?
ReaperSS
Aug 29, 2014 11:35 AM
JoeD
Apr 2, 2014 06:49 AM
The_Maniac
FWD Tech Guides '95-'07
Jan 26, 2014 05:54 PM
joeg1286
Mar 26, 2011 09:02 AM
mr202monte
Oct 31, 2010 02:09 PM
