A stuck temperature guage
Old Apr 8, 2007 | 09:37 PM
lindabanfield's Avatar
Default A stuck temperature guage
The temp. guage on my 2001 is not registering any temperature at all. On April 5 I left Florida going to TN. The temperatures were below freezing here. My poor car had never seen snow let alone freezing temperatures before. I had no problem in FL butnow there is a whinning sound coming from the engine and the guage is not working. If I drive the car for awhile the noise in the engine will stop but will sometimes start up again and then stop again. There are no indicator lights coming on. What is the problem and should I have this fixed before I head back to FL?
Frozen in TN!!!
Old Apr 8, 2007 | 11:01 PM
Mrrench's Avatar
Default RE: A stuck temperature guage
sounds like a temp sensor along with a needed thermostat....
Old Apr 9, 2007 | 01:57 AM
enibum's Avatar
Probably just your t-stat. It is probably stuck open. Mine had did the same thing about two months ago. I'll bet your heater don't get very warm either. I replaced my t-stat and everything started working again. I replaced it with a stock unit.
Old Apr 9, 2007 | 02:15 AM
Mrrench's Avatar
I always recommand replacing the sensor at the sametime since it is right there.
It should only cost an extra 17 bucks or so....
Old Apr 9, 2007 | 10:14 AM
wiz kidd's Avatar
i say the same thing...if your there changing the t-stat you may as well do the coolant temp sensor @ the same time..its cheap and its an easy fix...and a big headache if you have to tear it all apart again if the t-stat wasn't the only problem... its a pain in the but doing the same job twice
Old Apr 9, 2007 | 10:20 PM
04 Intimidator's Avatar
Ohh, and welcome to the Monte Carlo Forum Linda!!!!!
Josh - how much larger are you going to make your sig? LOL
shaper18
Mar 20, 2011 07:22 PM
neil0215
May 27, 2010 09:43 PM
big green dog
May 12, 2005 12:04 PM
the4thlast1
Apr 26, 2005 08:41 PM
mghtymonte
Jul 30, 2004 03:29 PM
