Rumble noise
Rumble noise
04MC SS From a dead stop, if I drive it normal - its just fine, nothing wrong, when I get on it, theres this growl like teeth on two gears skipping over each other or the sound of a car going really fast down a dirt road, and it dont move for 2-3 seconds. Could this be transmission issues? Also, while driving, the tach is bouncing up and down like crazy. I love this car, but I have worked on it more than had fun in it.
Have you dropped the pan since this started? If you drop the pan / cut open the filter and see debris (actual metal, not just clutch wear) then the trans will need rebuilt. The things I can think if that would make grinding / growling would likely be producing debris.
What kind of mileage is on it?
But honestly if youre hearing grinding sounds also and the trans has never been touched, youre probably in for a rebuild or replacement if you dont just scrap the car.
Just by chance, if its the transmission, can this cause problems that sound like engine misfiring, not idleing correctly, muffler and pipes
6th Gen ('00-'05): Help With Noise!!!
michelob
02-15-2020 05:04 PM
rgant_19
23
07-24-2009 02:59 PM
