2003 monte carlo ss dome light and truck light not working
Old Feb 21, 2019 | 07:57 PM
cortesjr's Avatar
Default 2003 monte carlo ss dome light and truck light not working
So i have a 2003 monte carlo ss i bought and the dome light didnt work so i noticed the fuse wasnt in so i put fuse and bam it worked but i got a heavy night of rain and noticed the passenger floor wet so i did some investigating and found it needed a water deflector which i bought but noticed water was getting the passenger side fuse box wet and the lights didnt work so i put a new fuse it which was blown and instantly it popped i tried another and it popped again...any ideas anyone??
Old Feb 22, 2019 | 06:32 PM
Just saw you comment about a sun roof drain on another post. I would verify:
- The door closes completely
- The door seal is not damaged/kinked/collapsed
- The window is completely sealed.
- Check the sunroof drain tube is clear on that side and not damages (I believe it travels down the A-pillar, if someone ever removed that pillar piece and damaged the tub, that could be a big issue).
Old Feb 23, 2019 | 05:25 AM
Jeffs02rwdSS's Avatar
Check the cabin air filter , the rubber seal that hold the plastic cover down sometimes comes loose and will let water enter the car.Good luck
Old Feb 25, 2019 | 01:41 AM
cortesjr's Avatar
i did i did have a leak thru air filter but out a water deflector in and it stopped water from coming in
FatalcMCSS
Jul 23, 2019 09:43 PM
dthoren
Jan 17, 2014 11:54 PM
jman340
Mar 20, 2012 08:18 PM
mikes03ss
Oct 23, 2009 11:34 PM
jackal_71671
Sep 20, 2009 11:52 AM
