7th Gen ('06-'07): Windshield rear view mirror
Old Oct 8, 2021 | 06:36 PM
SSblack06's Avatar
Lightbulb Windshield rear view mirror
My rear view mirror is damaged and I would like to replace it. It has OnStar and auto dimming. I found a replacement that looks exactly the same. I am wondering is this a plug and play type of repair. Or will there be programing issues or something since OnStar is involved? Anyone out there that has done this would appreciate any help you can provide. Thanks for listening.
Old Oct 9, 2021 | 09:38 AM
The mirrors are plug and play, no programming required.
Old Oct 9, 2021 | 09:53 AM
Well hang on.. I was talking with someone on here a couple months ago (@GreyGhost?) and I think he said there are two different kinds. Something about pin count in the plug maybe. Ill try to find the topic.
EDIT: Cannot find the thread but im almost certain it turned out that the mirror I had was different from his although they both were auto dimming with on star.
Old Oct 10, 2021 | 10:51 AM
SSblack06's Avatar
Thank you so much for your help. I have ordered a replacement already.
Old Oct 10, 2021 | 10:54 AM
SSblack06's Avatar
I am aware of the two types of mirrors. The one I am going to order is identical to the one I have in my vehicle now. Everything matches down to the numbers on the back as well as the plug in. Thank you for you assistance!!!!
Old Oct 10, 2021 | 11:08 AM
Onstar vs non-Onstar mirrors do have different connectors, correct.
Old Oct 15, 2021 | 09:59 PM
Duder1no's Avatar
Default How to remove 2000 Monte Carlo SS rear view mirror
My rear view mirror was heat damaged when I bought it. I couldn’t find an explanation of how to pull it off so after messing with needle nose pliers and a flathead i tried removing what I thought was the cover with a pair of vice grips… got more than I bargained for. If you encounter this type of mount, just slide a flat head in from the top and torque down and the mount will come off the base. I’m new to working on cars… so I’ll file this as a lesson learned. Sweet car though!
So far I’ve replaced the EVAP Solenoid, gas cap, wipers, a Y joint to bring windshield fluid to the wipers, flasher switcher, and multi- function switch. Next up is the bumper.
Old Oct 16, 2021 | 02:27 PM
OUCH! That is some serious windshield damage
Sorry to see that.
Old Oct 17, 2021 | 07:27 AM
Duder1no's Avatar
Default Glued right back on
SSblack06
Jun 4, 2020 07:04 PM
Elove1987
Aug 28, 2014 12:42 AM
celloyd
Sep 21, 2013 11:44 AM
mwjames
Aug 11, 2013 08:45 AM
jay26
Jul 15, 2007 04:59 PM
