window problem.
Old Mar 8, 2008 | 11:52 PM
98monte's Avatar
Default window problem.
my window on my drivers side wont go up.. it rolled down but wouldn't roll up and my other windows works... so can anyone tell me what the problem is? did it slip off track or something? it doesn't make no noise when i try to roll it up.. i'm takin it off tomo to see if i c anything thought i would get some options tonight
Old Mar 9, 2008 | 12:03 AM
mickey's Avatar
Default RE: window problem.
try to see if you can revers the switch on it and see if the switch went bad. or if the motor did.
other then that make sure tha they are still pluged in
Old Mar 9, 2008 | 12:12 AM
98monte's Avatar
when u say switch u mean the button that u press to roll it down? take the one from the passenger side and put it on tyhe driver side and c if it rolls up?
Old Mar 9, 2008 | 12:23 AM
kweef's Avatar
if ur gonna pop the panel off to change the switched make sure that it hasnt fallen off the track...that can happen as well
Old Mar 9, 2008 | 09:18 AM
blazerman3's Avatar
Yeah,try the switch in the other door first...just the process of ilimination...good luck!
Old Mar 9, 2008 | 11:48 AM
mrl390's Avatar
Probably the window motor and/orregulator. I think that is a common problem with the 5th gens.
Old Mar 9, 2008 | 09:19 PM
TheFullMonte's Avatar
i'd say the power windowmotor is bad. most of the time they will roll down but dont have the juice to roll back up. check it out before buying any parts.
jeffsmonte
Nov 21, 2022 07:34 AM
Jester_20
Aug 24, 2014 02:29 PM
02 Earnhardt Monte Carlo SS
Nov 10, 2011 10:13 AM
ChevyMan2008
Mar 8, 2008 09:29 PM
TrapShooter8
Jun 3, 2007 08:31 PM
