window and lock switch, no light
Old May 27, 2009 | 03:02 PM
weizie's Avatar
Default window and lock switch, no light
i noticed that the window and light switch on my passenger door dont light up like the ones on my driver side. any one know where i can look or check to fix this problem. and half of my AC control panel doesnt light up either, any sugestions?
Old May 27, 2009 | 03:05 PM
The Popcorn King's Avatar
SOunds like the bulbs need to be replaced on the switch and the A/C controls. I know that alot of people just solder in LEDs cause the bulbs have to soldered off anyways.
Old May 27, 2009 | 03:08 PM
weizie's Avatar
ah ok im not familiar with soldering is it hard to do? and where would i get the lights?
Old May 27, 2009 | 03:10 PM
They are a P.I.T.A. to replace because you have to tear your whole dash off, and then take the controls apart to solder the LEDs in. We have a write-up somewhere.
Old May 27, 2009 | 03:20 PM
weizie's Avatar
well takin the dash off to get the AC control panel is easy, i have taken it off enough to play with my stereo.....how would i find the write up?
Old May 27, 2009 | 07:16 PM
jeff2425's Avatar
for the door panel lights you will prob need to do that youself. check out bbengineer.com for the the ac/heat control unit. ship it to him and you can pick the color led you want and he ships it back all fixed up. he also does speedo cluster bulbs too.
DerrtyD
Apr 26, 2013 11:49 AM
robknight13607
Mar 23, 2013 08:57 PM
jim1405
Sep 24, 2012 04:40 PM
saigashooter
Apr 20, 2012 03:55 PM
jeffrae
Dec 21, 2007 04:30 PM
