Window won't go up
Old May 27, 2009 | 08:53 PM
NJ Gregg's Avatar
Default Window won't go up
Hi, Have a 2000 SS. Drivers side window will go down fine, but will only go half way up. If I shimmy the window position then I can get it to go up all the way. Is that the window regulator or the switch? Thanks
Old May 27, 2009 | 09:08 PM
The Popcorn King's Avatar
Welcome to the forum.
I wanna say its the regulator. Take the door panel off and try raising it again. You will see where its hanging up. I know that on fleabay they have replacement regs.
Old May 27, 2009 | 09:27 PM
kweef's Avatar
take the panel off and make sure the track isnt twisted or bent... what do u mean by shimmy?
Old May 27, 2009 | 09:36 PM
I think he means that he grabs the window and kinda guides it up.
Old May 27, 2009 | 09:53 PM
NJ Gregg's Avatar
Yup, that would be my defination of shinny
Old May 28, 2009 | 10:54 AM
sonin66's Avatar
is the rubber between the window catching?
Old May 28, 2009 | 11:00 AM
first thing I would do is definitely take the door apart. It's easy to do and see if something came loose. No sense buying a part if a screw just fell out
(I had a screw fall out of mine and the window was off track and sucked)
jeffsmonte
Nov 21, 2022 07:34 AM
rjo98
Aug 15, 2011 10:36 AM
tekboi
Dec 6, 2010 06:25 PM
waywardangel
Nov 2, 2009 08:52 AM
TrapShooter8
Jun 3, 2007 08:31 PM
