Window.
Old Jan 10, 2012 | 07:01 PM
7498MonteCarlo's Avatar
Photobucket
Monte Of The Month -- August 2010
Default Window.
Just gonna cut to the chase, without the BS.
Why does my driver's side window (97 LS) intermittently not want to go up?
Gold car did it too.
Old Jan 10, 2012 | 07:44 PM
thats funny, my drivers window is a real pain in the but too
Old Jan 10, 2012 | 09:40 PM
Jester_20's Avatar
could be a couple different things......most likely it's either the switch or the motor going out. Hopefully it's just the switch could be a loose wire or bad connection. that's my best guess
Old Jan 10, 2012 | 09:49 PM
The switch could be corroded or dirty. I have a 94 Grand Prix and the drivers side does the same thing. Probably because it is used the most.
Old Jan 10, 2012 | 09:57 PM
Id say a switch if its just random if it was constant than it be the regulator
Old Jan 11, 2012 | 12:06 AM
Sliver's Avatar
Happened on my 01, turned out to be the switch.
Old Jan 11, 2012 | 08:41 AM
Mine couldn't be the switch as its a constant issue, you have to help it up and down or it wont work much.
Old Jan 11, 2012 | 08:47 AM
Keane yours sounds like my GTO which was the regulator
Old Jan 11, 2012 | 04:21 PM
Photobucket
The switch might be the problem on this car. Though my aunt never rolled the windows down when she had it.
When I put a new switch on the gold car, it still did it. The whole window assembly was just worn out on that one though. Track was loose and sloppy. Went up and down a lot better though after greasing the tracks.
jeffsmonte
Nov 21, 2022 07:34 AM
Jester_20
Aug 24, 2014 02:29 PM
02 Earnhardt Monte Carlo SS
Nov 10, 2011 10:13 AM
TrapShooter8
Jun 3, 2007 08:31 PM
montecarlo1995
Jul 6, 2005 05:06 PM
