Turning Signal
Could be a few things, the multi-function switch itself, the hazard switch on your dash, or even a problem with a brake light can mess with this.
Most commonly it is your multifunction switch. Sometimes the connection goes bad and you can try to shoot something like WD-40 in there to make clean up some debris, but keep easy on it and hope it doesn't go.
The new one will be here this week.
