Vibration when turning
Old Mar 25, 2007 | 06:01 PM
oldude's Avatar
Default Vibration when turning
New member and my first ques. We just got a 01 monte ss and have a problem I could use some help with. When I drive at highway speeds and go thru a right curve while accelerating it vibrates thru the floorboards and driver side door. No vibration thru the steering wheel. I talked to the people we bought it from ( my daughters in laws) and they said they had the wheel bearing/hub replaced about a yr ago but didn't fix the prob. Any ideas?
thanks
dan
Old Mar 25, 2007 | 07:52 PM
Mrrench's Avatar
Default RE: Vibration when turning
Check the axle out
Might be the cv joints going bad
And the other things that I would check would be the engine and transmission mounts.
Old Mar 26, 2007 | 03:23 AM
2000LS's Avatar
tried rotating tires left to right to see if it moves?
Old Mar 26, 2007 | 10:19 AM
oldude's Avatar
Thanks; I'll check those things out.
Old Mar 26, 2007 | 10:20 AM
wiz kidd's Avatar
is it only when you turn one direction?? does it make any noise along with the vibration??
Old Mar 26, 2007 | 05:38 PM
oldude's Avatar
Only when going around a right hand curve at highway speed and giving it gas. If I coast thru the same curve it is fine. Maybe a slight grinding sound, but my hearing isn't the best.
Old Mar 26, 2007 | 06:03 PM
wiz kidd's Avatar
how many miles on the car?? it could be a front hub assembly...or a c.v shaft...
sounds to me like one of those 2...hubs are common on these cars...luckily they're not that expensive considering they have the sensor on them...dont get ripped on it if thats what you need...try to get a BR930548k hub from a auto parts store...cdn its about 180 or so + tax, so i could only imagine its cheaper in the states...dont buy anything cheap...and the delco ones aren't really the greatest either
Old Mar 26, 2007 | 06:50 PM
oldude's Avatar
124,000 miles. The people we bought it from said they had a bearing/hub replaced about a year ago but that didn't solve the prob. I don't believe it could've been this bad for a year tho. They offered to pay for the repair but, if it's something I can fix myself I'll go ahead and do it.
******************** UPDATE ************************
It was the inboard CV joint on the left side (drivers). I replaced the axle and no more vibration.
tictacxo
Sep 16, 2012 09:47 AM
anarchy1974
Jan 7, 2011 06:25 AM
zipsayain
Feb 25, 2007 09:29 AM
White05LT
Aug 26, 2006 09:13 AM
J_Bru_Ha_SS
Aug 10, 2006 11:05 AM
