Turning Signal
At times when driving, my turn signals decide not to work for short periods of time... any ideas why? Any suggestions?
Could be a few things, the multi-function switch itself, the hazard switch on your dash, or even a problem with a brake light can mess with this.
Most commonly it is your multifunction switch. Sometimes the connection goes bad and you can try to shoot something like WD-40 in there to make clean up some debris, but keep easy on it and hope it doesn't go. |
turn signal remedy
next time they don't work just push the 4way hazard switch off to the side or wiggle it. don't push it on ,give it a wiggle. mine is the same way. this forum suggested to replace the 4way,but why? just give it a wiggle.
yup...mine has done the same thing before. Just wiggle the hazard switch and it's working again.
Originally Posted by dmfonline
(Post 177516)
The new one will be here this week. :cool: |
