turn signals buzz, intermittant no start -FIXED
Old Oct 9, 2008 | 02:28 PM
cmamtm's Avatar
Default turn signals buzz, intermittant no start -FIXED
i have a 2000 monte ls. i was having frustrating issues with the turn signals not working, but causing the hazard flaser to buzz. also most of the dash warning lights would come on intermittently. i also had intermittent no start condition. i changed the hazard flasher with no results. i changed the multi-function switch with no results. i changed the key cylinder with no results. i chased all the commonly known BCM harness issues. i finally tried another key cylinder, but with no results again. BUT while i had the ignition switch assembly out of the dash i noticed i could start the car by holding in on the 2 harness clips on the back of the ignition switch assy. yep that was it. loose connection. i took a pair of needle nose and gave the male terminals on the ignition switch a slight twist so they would make better contact with the harness connector. a slight twist is all it takes. the harness connectors were slighly hard to push back into place. so far, so good. all is well... hopefully this will keep someone from buying the hi dollar key assy or the hi dollar BCM ( with dealer programming ) or wasting a lot of time on other items befor trying the reasonably easy and FREE fix.
Old Oct 22, 2016 | 10:05 AM
kgreseth's Avatar
Thanks Ill try that!
Robert-12-21
23
Nov 28, 2016 11:00 AM
PtownBubba
May 2, 2015 09:34 AM
RickCoMatic
Jan 20, 2013 08:57 AM
desertstars
Oct 31, 2009 02:58 PM
standupguy
Apr 4, 2007 02:36 AM
