Turn signal/wiper fluid issues
Old Feb 4, 2019 | 08:23 AM
BFerr's Avatar
Default Turn signal/wiper fluid issues
Hi, having some issues and curious if anyone has any ideas as to what the problem might be. I have a 2005 Tony Stewart Edition Monte Carlo SS.
My turn signals are flashing rapidly, (I changed the bulbs as well as the relay flasher and it didn’t fix the problem) and here is where it gets weird. They both flash (rapidly) when the car is in park. However, when I shift out of park, the right arrow on the panel faintly lights up, only the left directional will flash (again, rapidly) when I use it. If I put on the right directional in anything other than park, nothing happens. So flash, no sound, nothing.
And here’s another issue I believe is tied into it, same with my washer fluid. It only comes out when the car is in park. The wipers work all the time, but the fluid only works when it is in park.
I’ve checked fuses, cleaned wires, replaced the relay flasher, replaced flasher bulbs....I have no idea.
Any help or suggestions would be appreciated.
Thanks!
Barbie
Jun 17, 2019 09:09 PM
nfenner86
Jun 2, 2016 09:41 AM
monteriderLS
Apr 1, 2013 08:57 AM
gdogg090
Jun 25, 2011 03:16 PM
Artikmb47
MCF Website Problems & Issues
Apr 25, 2008 09:24 PM
