question about my car
Old Jan 8, 2009 | 02:37 AM
robertspangler's Avatar
Default question about my car
Ok i have the usual problem with the turn signals to where they wont work somtimes unless i turn my hazards on and off but my wipers work but they are in the up position all the time when the switch is turned off, can sombody tell me what this is /
Old Jan 8, 2009 | 05:23 AM
Cut Throat's Avatar
Default RE: question about my car
What year car do you have? It could be an electrical problem with the wiring, or turn signal switch.
Old Jan 8, 2009 | 08:03 AM
wiz kidd's Avatar
your wipers and blinkers are on the same switch?? could be that whole lever, which isn't usually that expensive, usually around $100-$150
it definetely sounds like an electrical issue, i would check out one of those switches though
its called a turn signal lever (or switch) with wipers
but then it could be something really stupid though too, the only thing thats making me think it has to do with that switch is that the wipers are stuck up @ the top when you turn them off.
Old Jan 8, 2009 | 03:14 PM
Mrrench's Avatar
replace the flasher
Old Jan 8, 2009 | 07:07 PM
kweef's Avatar
ur wiper governor could b junk...its the part of the wiper motor that decides where the wipers stop...and as i said in the other thread and as mrrench has suggested in this one ur turn signal is most likely the flasher module
Old Jan 8, 2009 | 07:19 PM
Ein's Avatar
Ein
I don't know that the turn signal is also the flasher. I am currently having issues with my turn signal switch, but i can still hear the tick of the flasher from under the dashboard. Also, a friend of mine has a WS6 (99') and it too has its own seperate flasher. This could be the same problem as mine, my right front turn signal will sometimes work after i mess with the hazards a little (whereas the from left always works). AC Delco turn signal switch = $93
Old Jan 8, 2009 | 09:54 PM
kweef's Avatar
hmm well the flasher module is the main control for both your turn signals and ur hazards...if after messing with your hazards your turn signals work again it would suggest that the 2 problems are related...hence your flasher module
96z34man
Jul 23, 2013 07:53 AM
70monte1
Mar 28, 2010 05:10 AM
2003supersport
Feb 4, 2009 09:15 AM
saluteTOme
Jun 3, 2007 05:58 PM
01PaceCarSS
Dec 29, 2006 08:26 PM
