Turn Signal stuck in position
Hey, I just replaced my Multifunction Switch and my Hazard Flasher Switch and turn signals themselves and hazard lights work fine..but it's when I make a Left turn and flip my switch to go that way, when I make the turn, the knob doesn't click back into original position, it clicks but sticks and I have to manually put it back in position by hand.
Any way to fix this or is it a problem with the Multifunction switch?? (Right turns work like supposed to) |
usually a broken spring
Originally Posted by volkerc
(Post 718439)
Originally Posted by FatalcMCSS
(Post 718514)
Inside the actual multifunction switch, isn't it?
(Post 718521)
Yes, there are two springs. you can buy just the springs.
