6th Gen ('00-'05): Trunk Entrapment bcm code.
Old Jan 7, 2023 | 09:00 PM
Jasencross's Avatar
Default Trunk Entrapment bcm code.
My service vehicle soon light is on. Checked the bcm code and it says trunk entrapment sensor. Everything works fine from my trunk release button and so forth. I checked the voltage at the sensor and I’m only getting 8 volts. Is that ok or should I be getting 12volts? I don’t know why this code wont go away even when clearing it.
Old Jan 8, 2023 | 04:02 PM
Off hand I am not sure. Most things in the car are 12v. What your Monte and what is the actual code number you got?
Old Jan 22, 2023 | 02:46 AM
Jasencross's Avatar
04 3.4liter. B3896 is the code. It’s a bcm code that has the service vehicle soon lamp illuminated. I’ve checked the wires and everything. The only thing I see crazy is I’m only getting like 8volts at the trunk release. The trunk release works. Even the trunk button on the interior of the car. The trunk lamp goes on and off as it should as well.
Old Jan 22, 2023 | 10:01 AM
I searched the shop book for that error code. Only ONE item came up. I attached a PDF of it.
The rear compartment occupant sensor can be disabled by pressing and holding the disable switch on the sensor for 2 seconds. When disabled, the BCM will command the trunk ajar telltale ON for 1 minute with each ignition ON signal while the sensor is disabled. Once the rear compartment is opened the sensor will reset to an enabled status, and resume normal operation. The sensor can also be enabled inside of the trunk, if disabled, with the ignition ON or OFF by pressing the disable switch. If the rear compartment occupant sensor is disconnected, the trunk ajar telltale will illuminate for 30 seconds with each ignition ON cycle, and DTC B3896 will be stored.The BCM monitors the status of the rear compartment occupant sensor through the trunk ajar switch signal circuit continuously. If the BCM detects a problem, a DTC will set and the service vehicle soon telltale will illuminate.
Not a bunch to work with unfortunately.
File Type: pdf
rednas
Mar 26, 2023 09:53 AM
blackmonte781
Jul 26, 2020 07:39 PM
N/A02NBMCSS
Jun 19, 2019 03:44 AM
willie8701
Mar 28, 2008 10:18 AM
montejass
Apr 15, 2005 11:41 AM
