bcm
Old Mar 26, 2008 | 09:31 AM
willie8701's Avatar
Default bcm
i have a 2001 monte that is acting crazy what does the bcm do and where is it located.
Old Mar 26, 2008 | 09:51 AM
bowtietech's Avatar
Default RE: bcm
The BCM is located above the parking brake pedal.It is a black box with 3 connectors. BCM failure is fairly common on a 2001. The BCM controls many electrical functions on the vehicle.When a BCM fails it can cause all sorts of electrical malfunctions. Exterior lighting acting goofy,various warning lights illuminating on the instrument panel,no start,inoperative power locks,etc just to name a few. There is a bar code label on the BCM that has a date code on it. If the 3 digit numeric code is below 170 your BCM was manufactured before certain improvements were implemented.
Old Mar 26, 2008 | 10:03 AM
willie8701's Avatar
Default RE: bcm
thanks my abs,airbag,trac off,brake,come on it seems like the key was turned off but it does not stop running .
Old Mar 26, 2008 | 10:22 AM
willie8701's Avatar
Default RE: bcm
is there much to replacing it.
Old Mar 26, 2008 | 10:30 AM
kweef's Avatar
Default RE: bcm
if my memory serves me right there r three plugs that run into the bcm...i am not sure on the engine side what it takes but i havemy dashall torn apart at the moment so ill check it out when i get home for ya
Old Mar 26, 2008 | 11:03 AM
willie8701's Avatar
Default RE: bcm
thanks
Old Mar 26, 2008 | 12:28 PM
Cloud_Master's Avatar
Default RE: bcm
Is the reflash of the BCM worth while to do, or just get a replacement if below the better number? I would assume the replacement would need a flash as well??
ORIGINAL: bowtietech
Old Mar 26, 2008 | 12:33 PM
kweef's Avatar
Default RE: bcm
lol r u talking about ur pcm/ecu? cuz i dont think u can flash ur bcm...maybe im wrong but im not sure u can
Old Mar 26, 2008 | 12:52 PM
Default RE: bcm
I was told the BCM could be reflashed...........
Old Mar 26, 2008 | 02:04 PM
kweef's Avatar
Default RE: bcm
hmm ok ill check my tuner forum and let u know
