Trouble at idle
Old May 3, 2015 | 03:54 PM
04 SS/SC's Avatar
Default Trouble at idle
Runs fine for about 15-30 sec on start up then revs up and dies. Fine once driving. Was told by Zzp it was o2 sensor even tho no engine codes. I replaced it and still same problem. Engine trans have less then 30k on them. No codes showing need help?
Old May 3, 2015 | 04:17 PM
Check your fuel pressure at the fuel rail..
Could be clogged fuel filter or failing fuel pump.
Check/clean the IAC..(idle air control)
Old May 3, 2015 | 04:35 PM
Also it can't hurt to take the mass air flow sensor out and clean it up with some maf cleaner.
Old May 3, 2015 | 09:03 PM
04 SS/SC's Avatar
Cleaned the maf didn't help. What is required to check pressure at fuel rail? Fuel filter is new. Possibly on the pump never replaced that and it is maxed out on my set up
01whitess
Feb 18, 2013 08:55 PM
chorales
Jul 24, 2005 05:33 PM
bumpin_monte01
Jul 8, 2005 08:32 PM
becker2100
Jun 18, 2005 10:06 AM
85_Monte_SC
MCF Website Problems & Issues
Mar 11, 2005 06:38 PM
