Transmission vacuum modulator valve location
Old Sep 19, 2010 | 12:14 PM
sublime757's Avatar
Default Transmission vacuum modulator valve location
I have a 2004 MC LS 3.4L, automatic tranny, and like the title says I'm having trouble locating the tranny modulator valve. I've looked it up and down, but I'm not sure if it's behind a heat shield or some kind of housing. If someone could please point me in the right direction (a picture would be even better, haha) I would be very grateful. Thanks. Great site by the way.
Old Sep 19, 2010 | 12:52 PM
Welcome to the Monte Carlo Family...
I'm not a transmission tech, but I did a search for a vacum modulator valve, and could not find it in my search...
Are you rebuilding your trans ? What is your transmission doing ? Please post as much information as you can about your problem..
Check back to see if any of our expert transmission member's can assist with your thread question...
2004 Chevrolet Monte Carlo Auto Trans Control Solenoid Standard Ignition 04chemonte carlo/SITCS44
Above is all that I could find that even came close : )
http://www.theautopartsshop.com/sear...s&anoFollow=no
Good Luck, and check back on your Thread...
Old Sep 20, 2010 | 03:28 PM
sublime757's Avatar
It won't start unless you give it gas and hold it above 1k rpm. Almost no power on take off, hard shifts, poor gas mileage. I've tried everything. PCV valve, MAF sensor, fuel pump, fuel filter, fuel pressure regulator, checked hoses for vacuum leaks, etc. I had a Cadillac with the exact same symptoms and this ended up being the culprit. Here's the part, now I just need to find where to put it. http://shop.advanceautoparts.com/web...S_176267840___
alpine64
Jan 11, 2013 11:16 AM
GreenRaccoon
Oct 4, 2011 02:21 PM
roflcopter
Apr 9, 2009 02:23 AM
RickCoMatic
Nov 18, 2008 04:39 PM
mrittenhouse
Nov 17, 2008 05:33 PM
