Brake pressure modulator FYI
Old Nov 17, 2008 | 05:33 PM
mrittenhouse's Avatar
Default Brake pressure modulator FYI
Just thought I'd throw out an FYI to everyone that has around a 2001 Monte Carlo. I have an 01 SS and over the last 6 mths, I've had the ABS light and "service traction system" code which throws the traction control to "off". Those three things happen at the same time when you start the car and put it in motion. The problem is the ABS hub/harness assembly which was not cheap. The other problem I had was the same lights, but the radio would throw a code and shut off like the car was being stolen. Fancy feature, but it was the BCM or "body control module" responsible for distributing information from the main computer. The last few days, it was doing the same thing as before with the ABS light and traction code, traction turning off when you start rolling..... Dealership states it's going to be around $1100 to replace the "Brake pressure modulator valve." The part is around $900 and I'm assuming that's for the luxioury of them getting the part right then so they can replace it at $100/hr for you. I found the part on gmpartsdirect.com seen below. Select your year and model and "brakes"/"ABS"
http://www.trademotion.com/partlocat...amp;sectionids
I did the math and over the last 6 months, I could have made 6 $350 car payments on a car w/ less problems. It's got 107K miles and starting to hurt my wallet! Again, didn't know if anyone else was having this problem and thought I'd throw out a suggestion on what it might be if you are. Peace!
joe111599
Jun 10, 2016 07:01 PM
alpine64
Jan 11, 2013 11:16 AM
Randy Biron
Jul 14, 2012 08:07 PM
sublime757
Sep 20, 2010 03:28 PM
Dec 4, 2009 08:34 AM
