6th Gen ('00-'05): Transmission replacement
Old Jul 21, 2015 | 06:12 PM
plumbob's Avatar
Default Transmission replacement
I'm about to tackle removing and replacing the transmission in my '03 SS. I've done side case access repairs before, but complete removal will be a first for me. I'm getting some conflicting info. from guides. The factory manual says to completely remove the engine frame (cradle), but others say to just lower the driver side. This will be a driveway repair. Has anybody else out there tackled this? Any tips are appreciated.
Old Jul 26, 2015 | 10:40 PM
turbo monte's Avatar
I answered your pm as well but in short. The engine cradle needs completely removed to remove the trans out the under side. Once you remove the engine cradle you will need to realign the car.
Old Jul 26, 2015 | 11:05 PM
plumbob's Avatar
Got your PM and replied back. Thanks man, I think we're good to go once I get the trans at my house. Waiting for the JY to remove from car.
Old Nov 11, 2023 | 09:07 PM
lukewzim's Avatar
Would either of you guys be able to help me get my transmission out? I have removed a majority of bolts but it won’t budge. Can you help me with the locations of all bolts?
Old Nov 12, 2023 | 10:11 AM
plumbob's Avatar
Hi Luke,
My bet is that you missed the bolt connecting the transmission to the engine that has to be accessed from the passenger side with a 3 foot socket extension. It's in there deep and hard to see, even harder to put back in...lol.
Old Nov 12, 2023 | 10:17 AM
lukewzim's Avatar
Originally Posted by plumbob
Hi Luke,
I agree. Is this visible from any location? Which way is the best way to get this out?
Old Nov 12, 2023 | 10:22 AM
I would also consider replacing that bolt if you tried to lift the engine with it still attached. Youd probably be fine if thats the case but better safe than sorry.
Old Nov 12, 2023 | 10:24 AM
lukewzim's Avatar
Will do. Do you have a picture or a specific spot I need to be looking at to get this bolt out?
Old Nov 12, 2023 | 10:44 AM
plumbob's Avatar
With the passenger side wheel removed, aim a flashlight into the darkest area where the engine and transmission meet. The bolt has the same head size as all the other mating bolts, but is longer.
SuperCracker98
Mar 31, 2021 08:54 AM
03vaderSS
Oct 23, 2019 09:04 PM
Jaymoung
Feb 11, 2017 11:16 AM
bigwill250
Mar 22, 2014 03:06 PM
seanzyyy
Apr 21, 2009 04:14 PM
