transmission replacement help
Old Mar 21, 2014 | 08:24 PM
bigwill250's Avatar
Default transmission replacement help
what is the easiest way to change the transmission on my 2002 monte carlo? Pull motor? Don't pull motor??
Old Mar 22, 2014 | 12:04 AM
turbo monte's Avatar
Let engine in car and support it from the top using fenders with a engine support bracket. Drop sub frame and take trans out the bottom. Easiest way I've found. Done this 3 times now lol
Old Mar 22, 2014 | 03:06 PM
seen03's Avatar
I concur with the previous post. I've swapped transmissions now...and I'm actually in the process of doing another swap right now. I'd recommend having 4 Jack stands and 2 floor jacks handy...it makes removing the subframe and the trans a bit easier. Sometimes I've removed the struts completely just to have them outta the way.
Oh, and when u start lowering the subframe...I remove one side's bolts first..lower the jack (and subframe), then repeat on the opp side. Also keep checking to see if any hoses or harnesses are still attached to the frame, so u can disconnect them before they rip off.
plumbob
Nov 12, 2023 10:44 AM
Budsjlm
FWD Tech Guides '95-'07
Oct 29, 2015 05:01 PM
Great White North
Jul 16, 2007 02:19 PM
BloodAndHonor
Jun 26, 2007 07:50 PM
seasoned vet
19
Oct 28, 2006 02:45 AM
