trac light and abs problem, already installed new hubs...
thanks for the info nightmagic.
the ground under the airbox has been redone when the top swap was done, so i know that is good. i will double check the wires and the connections this weekend when its almost 60*, finally. i am also planning on putting on new pads this weekend my parts shipment shows up on friday.
i am just hoping its not the abs pump or rear hubs. though the rear hubs wouldnt be surprising if they were shot. the fronts had never been replaced and had over 220k.
and i also want to let you know that a bad ground will also make the pcm not read correctly as well. i had mine tested and the only thing it kept on bringing up was a bad abs pump...which is odd. and a very expensive part. so even if you have it scanned you could be misled. good luck!
6th Gen ('00-'05): Fixed my ABS and TRAC off light issues
peterjwsong
02-24-2014 06:52 AM
ladagosta
08-24-2012 09:54 AM
3xBlk'monte'ss
06-15-2012 05:36 PM
