ABS and TRAC light lite up on my dash does anyone have a clue why ?
Old Jun 15, 2012 | 03:34 PM
3xBlk'monte'ss's Avatar
Default ABS and TRAC light lite up on my dash does anyone have a clue why ?
Sooo the ABS and Trac indicator came on and i was hoping someone might have an idea why this would happen and if there is an easy solution to this?
Old Jun 15, 2012 | 03:38 PM
Typically this is because a wheel hub assembly is going bad.
Or the wiring to the hub is going bad.
Or the ground under the airbox is really dirty.
Old Jun 15, 2012 | 03:52 PM
Thx Chibiblkshp im going to check that out...i just had all 4 hubs done so im hoping maybe a connector is loose ..does that make sense?
Old Jun 15, 2012 | 03:56 PM
Yes a connector could be dirty from the install. They can be a pain to get to, removing the tire could make it easier
Old Jun 15, 2012 | 04:06 PM
Thanks again chibiblkshp for taking the time to help.
Old Jun 15, 2012 | 05:36 PM
aussiek2000's Avatar
Were they cheap hubs? I have seen cheapies cause the code to come right back.
Bobbo51508
Feb 21, 2018 02:58 PM
vikesfan
Mar 27, 2014 09:25 AM
peterjwsong
Feb 24, 2014 06:52 AM
peterjwsong
Feb 19, 2014 07:45 AM
ladagosta
Aug 24, 2012 09:54 AM
