Tire pressure light
Old Sep 9, 2012 | 06:48 AM
03SSLE's Avatar
Originally Posted by BeefSS
Uhmm that a hellofa cheat code but I have a aftermarket system so no chimes anymore and it's not working for me
This method should still work even with an aftermarket stereo - you just wouldn't hear the chime unless you installed the module. Are you positive the key is in the ON position and not the ACC position?
Old Sep 9, 2012 | 07:48 AM
Possum's Avatar
So if it popped up on your MC dash now u would still use the black tape?
I put the tape on AFTER several costly trips to the mechanic, who tested everything and couldn't find anything wrong. All major systems on the Saturn had been repaired over the 13 years I owned it. Hopefully, this won't happen with the Monte.
Old Sep 9, 2012 | 06:38 PM
BeefSS's Avatar
Default Winner
Originally Posted by Mr Grizzly Mint
disconect battery for 5 min. all sensors shut down. takes awhile for them to come back online but will reset your code.
Thank U it worked
Old Sep 9, 2012 | 06:45 PM
Mr Grizzly Mint's Avatar
np. wire a stock radio into the trunk and only hook up the connection to the computer to make it easier to reset codes. dont hook up the actual radio or speakers. Makes things way easier. Or just keep disconnecting battery when you flip a light. Works on all warning messages.
joe111599
Jun 10, 2016 07:01 PM
Ulsterman
Aug 12, 2008 02:13 PM
MotorTSki
Apr 20, 2008 11:25 PM
amberblk00
Sep 12, 2007 03:03 PM
Greeny
Oct 30, 2006 11:50 PM
