is this tire any good?
Old Sep 2, 2013 | 01:21 PM
inyanalili's Avatar
Default is this tire any good?
is this tire any good with this defect?
File Type: jpg
Old Sep 2, 2013 | 02:26 PM
JC Colon's Avatar
Hello Inyanalili,
I wouldn't use that tire. It looks like the beed is cracked and rusted. The beed is the part of the tire that seals it to the rim, keeps the air in. With the crack and the rust you could end up with a flat at any time or worse, a blow out. If it will even hold air I wouldn't put that tire on my bicycle!
Old Sep 2, 2013 | 02:47 PM
I wouldn't want to drive with it on, but it could `be used
for a swing ?
Old Sep 2, 2013 | 03:13 PM
IMO THAT TIRE IS JUNK
lIKE sPACE SAID:
iTS PERFECT FOR A TIRE SWING!
Old Sep 2, 2013 | 04:21 PM
I personally wouldn't use it. I think it would end up being more trouble then it's worth. That bead is tore up and fibers pulling out of it. Possible candidate for a tire swing like Space suggested.
Old Sep 2, 2013 | 04:24 PM
JC Colon's Avatar
Default ZJerry
Correct me if I am wrong, But how can the beed seal if, what looks like, 3" of it is missing rubber? The beed on the tire, and the valve stem, is what holds the air in!
Old Sep 2, 2013 | 04:50 PM
Zen's Avatar
Zen
Sorry to tell ya. But that tire is toast. I've replace so many tire that other shop put on with torn beads. They almost never hold air an a lot will bulge in that area. Time for a new tire.
brady73monte
Mar 20, 2014 10:29 PM
Jul 2, 2012 09:03 AM
jeffsmonte
May 26, 2011 07:23 AM
esquire2021
Nov 23, 2010 09:58 PM
Greeny
Oct 30, 2006 11:50 PM
