is this tire any good?
Hello Inyanalili,
I wouldn't use that tire. It looks like the beed is cracked and rusted. The beed is the part of the tire that seals it to the rim, keeps the air in. With the crack and the rust you could end up with a flat at any time or worse, a blow out. If it will even hold air I wouldn't put that tire on my bicycle!
IMO THAT TIRE IS JUNK
lIKE sPACE SAID:
iTS PERFECT FOR A TIRE SWING!
I personally wouldn't use it. I think it would end up being more trouble then it's worth. That bead is tore up and fibers pulling out of it. Possible candidate for a tire swing like Space suggested.
Correct me if I am wrong, But how can the beed seal if, what looks like, 3" of it is missing rubber? The beed on the tire, and the valve stem, is what holds the air in!
2nd Gen ('73-'77): Finally got some rims for my monte, what is a good tire size that will fit?
brady73monte
Mar 20, 2014 10:29 PM
