tie rod help
If I remember correctly it just threads off.
Edit: I found this on google http://wiki.answers.com/Q/How_do_you...ols_are_needed
I think there's a special tool you need to remove and replace the tire rod. Check you tube on removing the inner tie rods. Might help. Why do you think it needs replacing. Its usually the outer tie rods that need replacing.
