Stock replacement Wheel Hub and Tie Rod???
Old May 17, 2011 | 12:48 PM
irulesoha's Avatar
Default Stock replacement Wheel Hub and Tie Rod???
I've searched the google a bit looking for stock replacements wheel hub assemblys and tie rod ends for my 2006 Monte Carlo SS after the local goodyear quoted me $200 for parts each hub and 100 each tie rod.
I've seen a whole bunch of them, but I have no idea which one to buy. Can someone send me a link to a stock, or better-than-stock hub assembly and tie rod?
MUCH appreciated.
Old May 17, 2011 | 05:50 PM
I was told by my mechanic to use Timken bearings, I replaced the back and purchsed it from Amazon, copy and paste the 2 listed below into amazon and they should be the ones you need for your Monte....
Timken HA590093 Axle Bearing and Hub Assembly (front)
Timken HA590092 Axle Bearing and Hub Assembly (rear)
brockkrak
Jul 17, 2012 02:35 PM
MONTE CARLOS
Aug 9, 2011 09:09 PM
cheebah
Nov 22, 2010 09:43 PM
mksiler
Mar 24, 2009 07:55 PM
BloodAndHonor
Jun 26, 2007 07:50 PM
