Outer tie rod issue
Old Nov 22, 2010 | 03:26 PM
cheebah's Avatar
Default Outer tie rod issue (solved)
Hi all,
little advice for other noobs...make sure you put your tie rod end the right side up.
Doug
Old Nov 22, 2010 | 05:13 PM
mrl390's Avatar
Did you install them on the correct side of the hole in the knuckle? The shaft is tapered and so is the hole in the knuckle that the shaft goes through. If you put it in the wrong side, the shaft wont seat correctly.
Old Nov 22, 2010 | 06:47 PM
cheebah's Avatar
holy ****! are you freakin kiddin me...i put the stupid things on upside down...wow thanks bro
Old Nov 22, 2010 | 09:43 PM
mrl390's Avatar
Hey dont mention it. Hope that solves your problem.
BrandonStebing
May 18, 2015 11:18 AM
brockkrak
Jul 17, 2012 02:35 PM
thewhitestcarlouknow
Mar 29, 2012 11:32 PM
mksiler
Mar 24, 2009 07:55 PM
BloodAndHonor
Jun 26, 2007 07:50 PM
