tie rod help
Old Aug 2, 2011 | 03:56 PM
MONTE CARLOS's Avatar
Default tie rod help
I can not for the life of me take my inner tie rods off is there a special way to do it or what can anyone help me
Old Aug 2, 2011 | 09:36 PM
If I remember correctly it just threads off.
Edit: I found this on google http://wiki.answers.com/Q/How_do_you...ols_are_needed
Old Aug 4, 2011 | 06:09 PM
kingreyna's Avatar
I think there's a special tool you need to remove and replace the tire rod. Check you tube on removing the inner tie rods. Might help. Why do you think it needs replacing. Its usually the outer tie rods that need replacing.
Old Aug 9, 2011 | 09:09 PM
Thanks for the help come to find out it was the bearings saved me some trouble
brockkrak
Jul 17, 2012 02:35 PM
irulesoha
May 17, 2011 05:50 PM
cheebah
Nov 22, 2010 09:43 PM
mksiler
Mar 24, 2009 07:55 PM
BloodAndHonor
Jun 26, 2007 07:50 PM
