Inner tie rod replacement on 98
Old Feb 6, 2011 | 12:34 PM
brockkrak's Avatar
Default Inner tie rod replacement on 98
How hard is it to replace a inner tie rod end on a 1998 Monte Thanks
Old Feb 20, 2011 | 07:18 AM
99inprogress's Avatar
not too hard. just make sure you have a pickle fork, and a couple of good jack stands. it might just save you a lot of headaches.
Old Nov 9, 2011 | 02:52 PM
feltes94's Avatar
i am not sure what i need but when i turn far left or far right i hear this loud click sound like when you brake a stick any ideas what that could be?
Old Jul 17, 2012 | 02:35 PM
Finger65's Avatar
if no one answered your question, its your ball joints. if its a 98 your lower ball joint is riveted in so you will have to drill/torch/grind out the rivets to replace. but aftermarket is easy bolt in. just sadly non-grease able. unless someone can find you better aftermarket ones.
SSixgun
Jun 27, 2015 10:30 PM
rcohen
Dec 10, 2011 09:39 PM
rcohen
Dec 10, 2011 09:38 PM
irulesoha
May 17, 2011 05:50 PM
BloodAndHonor
Jun 26, 2007 07:50 PM
