5th Gen ('95-'99): ticking sound in reverse
Old Aug 12, 2013 | 12:57 PM
bontrose's Avatar
Default ticking sound in reverse
The problem I am experiencing is as such:
The car makes a ticking sound while in reverse
-can be felt through shifter
-rapidity increases with speed
this problem started not long after i got the car, admittedly while i was still learning to drive and used drive instead of reverse in a parking space with a concrete divider but i digress.
when shifting into reverse the car does not tick, only when moving, either under its own power or an external power such as gravity on a slope.
update:does not occur in neutral
Last edited by bontrose; Aug 12, 2013 at 03:06 PM. Reason: update in terms of occourance
Old Sep 26, 2013 | 10:06 AM
bontrose's Avatar
problem went away when the parking pin got stuck in the trans
Sanjay Collins
Sep 20, 2014 03:16 PM
Nodachance
Aug 15, 2014 05:55 AM
Xavier Willis
Aug 25, 2013 09:15 AM
Endo
May 4, 2009 01:52 PM
04MonteLS
Apr 20, 2007 10:13 PM
