ticking sound in reverse
The problem I am experiencing is as such:
The car makes a ticking sound while in reverse -can be felt through shifter -rapidity increases with speed this problem started not long after i got the car, admittedly while i was still learning to drive and used drive instead of reverse in a parking space with a concrete divider but i digress. when shifting into reverse the car does not tick, only when moving, either under its own power or an external power such as gravity on a slope. update:does not occur in neutral |
problem went away when the parking pin got stuck in the trans
