6th Gen ('00-'05): Thud when tried to crank
Hard to say what's wrong. First thing you can try is to rotate engine backwards (counterclockwise as looking at from passenger fender) a little to see if starter is just stuck in out position. If motor doesn't rotate remove the belt and try again. Might be something as simple as a bad pulley, alternator or tensioner. Good luck
6th Gen ('00-'05): whining noise while trying to crank
dubb_b
Oct 29, 2017 10:32 AM
