99 Monte Carlo Wont Crank/Start
Old Nov 4, 2013 | 05:20 PM
frgivn's Avatar
Default 99 Monte Carlo Wont Crank/Start
Hello all,
I have a 99 Monte Carlo Z34. Occasionally the car will not crank when I try to start it. All of the dash lights come one like it should, but no cranking. If I let it sit for a while, it will start normally. This can range from about 5 minutes to over an hour. I have two "starter" keys and the problem exists with either key. The previous owner also installed a remote start in the car. This seems to happen most when we have either very cold or hot temps outside. I'm looking for the best place to start. To me, it seems like it could be the remote starter, key sensor, or ECU that could be the culprit, but I'm more than willing to hear suggestions.
Thanks for the help!
Old Nov 4, 2013 | 06:01 PM
z34phoenix's Avatar
does it make any sounds when its not starting? these cars are pretty stout. chances are it is the starter.
Old Nov 4, 2013 | 07:23 PM
Originally Posted by frgivn
Hello all,
Welcome to the forum.
I too have a 1999 Z-34... I would consider checking the battery terminals as well as the battery connections.. Just to eliminate that as a problem.
How long has that battery been in use? 3 to 5 yrs tops is considered the lifetime of a battery.
It could also be a faulty crank sensor rusted corroted connections... Depending on the climate /state you live in. Living in Michigan (Hot and Cold) yr round... I have never had a starter go bad.... But then again I am the original owner and have a high Maintenance program....
I'm not saying that it couldn't be the starter... I'm more leaning towards corroted connections,battery, crank sensor...
Hope this Helps!
I'm sure someone else may chime in to add some further suggestions..
Thanks for joining the MCF Family!
Old Nov 6, 2013 | 04:46 PM
frgivn's Avatar
Thanks guys. I have checked the battery, starter, crank sensor, etc. but everything seems to be working properly with these items. The problem comes and goes. I will drive all week with no problems, then it will happen. Stick the key in, turn it, all electrical, gages, etc. respond, but not so much as a "click" can be herd from the starter... nothing. After reading some of the other posts, I think I might be experiencing problems with my Passlock system.
Old Dec 1, 2013 | 05:05 PM
1996 Red/3.1 Monte's Avatar
Default fuel pump relay
Not my 1996 Monte, but I have another 96 car that had intermittent starting. Problem solved, it was the fuel pump relay that would withhold power to the electric fuel pump. Easy fix, unplug relay and install new one.
My 1996 Monte starts very quickly because I turn the key on and listen for the fuel pump to quit working in the tank and them turn to start, fires right up.
Old Jan 14, 2020 | 10:33 PM
Tamjaz1028's Avatar
Default 99 monte ls
99 monte ls and im having the same problem with mine we did the crank shaft sensor the cam sensor and new battery . the fuel pump is kicking in and the starter dose not make a clicking noise can any one help with this ?
Old Jan 14, 2020 | 10:42 PM
The starter doesn't need to make a clicking noise if it goes it can be silent, I know it was on mine.
scragun
Jun 17, 2014 04:10 PM
werewolf-odst
Apr 7, 2012 11:49 AM
SpaceAce
Dec 22, 2009 12:19 PM
NIEL305
Oct 14, 2008 06:41 AM
ilitrit
Feb 9, 2007 04:38 PM
