temp readings on cluster
Old Jan 20, 2013 | 06:14 PM
blueSS's Avatar
Default temp readings on cluster
So it's been awhile but i had to get rid of my monte recently. I'm looking at a cheap car a 1994 corsica with the 3.1 in it. My only worry about the car is the temp reading on the dash seems to show a lower temp than the car is actually running. The guy says he's replaced pretty much everything in the cooling system( radiator, hoses, thermostat). He also says he drilled a hole in thermostat to get rid of air pockets. The heater was blowing hot heat but the gauge was around 1/4 way or lower. The engine has also had all gaskets redone including head gaskets and intake gaskets. I'm wondering what the temp is for the lines on the cluster..? (pic below) Whats the low, quarter and mid temp mark? Should i be worried?
File Type: jpg
TETCarlo
Oct 11, 2010 12:25 PM
smolek37k
Dec 1, 2007 07:08 PM
ginasmontecarlo
Jan 27, 2006 03:40 PM
01whitess
Dec 20, 2005 03:29 PM
04MonteLS
Aug 21, 2005 09:19 AM
