Mirror lights not working
Old Jan 18, 2013 | 07:20 AM
robknight13607's Avatar
Default Mirror lights not working
2000 Monte with the Non-Onstar mirror, lights don't work but interior lights work. Anyone know if this is on it's own fuse?
Old Jan 18, 2013 | 10:05 AM
Red Nightmare's Avatar
try wiggling the pigtail in the rear of the mirror. Mine occasionally work, depending what position it is in.
Old Jan 18, 2013 | 10:12 AM
x2 my wiring is messed up too, sometimes it can be pinched and work for a month
Old Jan 18, 2013 | 11:20 AM
MonteCarlSS's Avatar
Mine also does this. If I wiggle it around a bit, they'll work, but usually when it's in the position I need it in, it doesn't work.
Old Jan 18, 2013 | 11:30 AM
Might also be worth checking the bulbs if the problem does not appear intermitant...
Old Jan 20, 2013 | 10:35 AM
ndaguanno's Avatar
I would say the wire also, mine keeps doing it, if you wiggle the wire they'll come back on. I have no idea why it does it, the wire and connection look fine.
Old Jan 20, 2013 | 06:42 PM
Might be a lose connector pin.... That looks ok... or the pinch holes that the pins go into maybe wider than there "normal" acceptable positioning.
Everything stretchs(wearsout) in time...
trav
Mar 29, 2022 08:56 PM
ladybridgeport
Jan 15, 2012 04:54 PM
cornerview
Sep 17, 2010 02:49 AM
bigmichaelcool
Nov 23, 2009 11:00 AM
thedude
Sep 1, 2006 10:26 PM
