Temp Gauge
Old May 24, 2007 | 08:56 AM
Nightmare!'s Avatar
Default Temp Gauge
2001 Monte SS (97500 miles) - Last week the Temp gauge (stock) didn't budge for a good 2 hours. Since then, it's been OK. Question, is there a sensor that could be going? If so where is it located and is it an easy fix? Anyone had similar problems?
Any info appreciated.
Thanx!
Old May 24, 2007 | 08:59 AM
wiz kidd's Avatar
Default RE: Temp Gauge
coolant temp sensor could be going...
its right beside the t-stat(on most vehicles...not 100% sure on ours as i haven't had to change it yet)
it should be where the upper rad hose meets the block is where the t-stat will be, change that and this sensor and should fix your problems
Old May 26, 2007 | 11:27 PM
enibum's Avatar
When the temp gauge wasn 't working, was it on a cool day? And when it started working, had the outside temperature warmed up a little. It could be your thermostat is stuck open. That's what happened to my 01SS. I replaced the thermostat and now my gauge works just fine. A lot of people replace the sensor and the thermostat at the same time. That's probably a good thing to do since you have to drain the radiator to do both. But for me I just replaced the thermostat and all is well. Hope this helps.
smolek37k
Dec 1, 2007 07:08 PM
01BlkSS
Dec 28, 2006 03:53 AM
SSmooth
Nov 12, 2006 05:20 PM
ginasmontecarlo
Jan 27, 2006 03:40 PM
01whitess
Dec 20, 2005 03:29 PM
